    6.1 Kernel Notebook Image Release
    25 Posts 6 Posters 1.8k Views
      • Customize the kernel using 6.1.75
      • NPU driver updated to 0.9.7
      • Support rkmpp video hardware decoding, with a maximum resolution of 8KP60
      • Delete default username and password, register upon startup
      • GPU driver defaults to using Panfrost
      W 1 Reply Last reply Reply Quote 0
      • W
        wzy @george
        @george 什么时候也更新一下cool-pi 4B
          george @wzy
          @wzy
          下周4b和CM5-EVB会同步更新。
          • W
            wzy @george
            @george 太棒了,期待(^o^)
              有办法保持现有系统升级么?
              还是说我解压缩了镜像自己拷贝走boot 和 firmware 之类的?
              这个内核开启 intel 网卡支持了吗?
                看了下 ppa 也更新了 mesa
                是不是我编译这个内核
                https://github.com/coolpi-george/coolpi-kernel
                然后更新这个 ppa 的 mesa
                https://launchpad.net/~george-coolpi/+archive/ubuntu/mali-g610
                最后放好 mali 的 firmware
                就可以使用新内核了?
                  已经编译了内核,用上了,不过发现个问题:声音输出写的是耳机,但是从喇叭出声,插了耳机依然是喇叭出声,不知道是哪里需要配置。
                  麦克风依然不可用。
                    @plumlis 系统上alsa的配置要修改。镜像已经上传到百度网盘。
                    plumlisP D 2 Replies Last reply Reply Quote 0
                      berkaroad
                      发现 dockerd启动失败,原因是iptables失败了,是否是内核未添加 nftables 的支持?
                      INFO[2024-08-18T11:25:10.884899381+08:00] Starting up
                      INFO[2024-08-18T11:25:10.885740562+08:00] detected 127.0.0.53 nameserver, assuming systemd-resolved, so using resolv.conf: /run/systemd/resolve/resolv.conf
                      INFO[2024-08-18T11:25:10.900679110+08:00] [graphdriver] using prior storage driver: overlay2
                      INFO[2024-08-18T11:25:10.908166906+08:00] Loading containers: start.
                      INFO[2024-08-18T11:25:10.955936893+08:00] unable to detect if iptables supports xlock: 'iptables --wait -L -n': `iptables: Failed to initialize nft: Protocol not supported`  error="exit status 1"
                      INFO[2024-08-18T11:25:11.035561219+08:00] stopping event stream following graceful shutdown  error="<nil>" module=libcontainerd namespace=moby
                      failed to start daemon: Error initializing network controller: error obtaining controller instance: failed to create NAT chain DOCKER: iptables failed: iptables -t nat -N DOCKER: iptables: Failed to initialize nft: Protocol not supported
                       (exit status 1)
                      INFO[2024-08-18T11:25:11.036588487+08:00] stopping event stream following graceful shutdown  error="context canceled" module=libcontainerd namespace=plugins.moby
                      从这里编译了内核: https://github.com/coolpi-george/coolpi-kernel
                      ./build-kernel.sh
                      sudo cp -r ./out/* /boot/firmware/ # 旧目录已经备份
                      B plumlisP 3 Replies Last reply Reply Quote 0
                        berkaroad @berkaroad
                        uname -a
                        Linux freshncp 6.1.75 #1 SMP Sun Aug 18 02:12:55 CST 2024 aarch64 aarch64 aarch64 GNU/Linux
                        之前的 5.10.110 是正常启动dockerd服务 的
                          @george 是修改 alsabase.conf么?
                          我对比了新景象和原来的配置文件,发现一模一样。
                          明天上班了做个启动U盘看看有没有声卡问题。
                            plumlis @berkaroad
                            @berkaroad 对比了 config ,感觉的确很多都没开启支持。
                            需要自己写进配置文件
                              看了下更新的 mesa,原来用的还是 panfork。
                              我说拷贝了 panthor 的 firmware 启动黑屏。😁
                                berkaroad @plumlis
                                @plumlis 6.1内核,我试了下,有声音(Headerphone),但麦克风不工作(看不到speaker)
                                我现在恢复到 5.10了,等稳定了再说。关于 iptable、nft 不能正常工作导致dockerd启动失败的问题,后边尝试改 内核编译配置验证了。
                                  berkaroad @plumlis
                                  @plumlis 6.1 用 george 发的链接更新 能正常不黑屏;5.10 用新的会黑屏,用备份的是ok的。
                                    @george 这个是5.10下的:
                                    lsmod
                                    Module                  Size  Used by
                                    xt_nat                 16384  5
                                    veth                   24576  0
                                    xt_conntrack           16384  2
                                    nft_chain_nat          16384  7
                                    xt_MASQUERADE          16384  3
                                    nf_nat                 36864  3 xt_nat,nft_chain_nat,xt_MASQUERADE
                                    nf_conntrack_netlink    40960  0
                                    nf_conntrack          135168  5 xt_conntrack,nf_nat,xt_nat,nf_conntrack_netlink,xt_MASQUERADE
                                    nf_defrag_ipv6         20480  1 nf_conntrack
                                    nf_defrag_ipv4         16384  1 nf_conntrack
                                    nft_counter            16384  33
                                    xt_addrtype            16384  2
                                    nft_compat             20480  12
                                    nf_tables             180224  132 nft_compat,nft_counter,nft_chain_nat
                                    br_netfilter           24576  0
                                    btusb                  53248  0
                                    btrtl                  20480  1 btusb
                                    btbcm                  20480  1 btusb
                                    8852be               3993600  0
                                    btintel                20480  1 btusb
                                    dm_mod                114688  0
                                    nfnetlink              20480  5 nft_compat,nf_conntrack_netlink,nf_tables
                                    所以 6.1的还得配置 nft,否则nft不可用,docker也不可用了。
                                      plumlis @berkaroad
                                      @berkaroad 我也先回到5.10了,反正切换也容易。
                                      同样的只有 headphone 没有 speaker 问题,麦克风 6.1 内核一直都不能用。
                                      不过 6.1 功耗更高了。
                                      B G 2 Replies Last reply Reply Quote 0
                                        经过测试,加了 nft 的内核配置后,可以正常运行dockerd了。
                                        > diff .config-bjr-addnft .config
                                        1063d1062
                                        < CONFIG_NETFILTER_NETLINK=y
                                        1065d1063
                                        < # CONFIG_NETFILTER_NETLINK_HOOK is not set
                                        1098,1120c1096
                                        < CONFIG_NF_TABLES=y
                                        < # CONFIG_NF_TABLES_INET is not set
                                        < # CONFIG_NF_TABLES_NETDEV is not set
                                        < # CONFIG_NFT_NUMGEN is not set
                                        < CONFIG_NFT_CT=y
                                        < # CONFIG_NFT_CONNLIMIT is not set
                                        < # CONFIG_NFT_LOG is not set
                                        < # CONFIG_NFT_LIMIT is not set
                                        < CONFIG_NFT_MASQ=y
                                        < CONFIG_NFT_REDIR=y
                                        < CONFIG_NFT_NAT=y
                                        < # CONFIG_NFT_TUNNEL is not set
                                        < # CONFIG_NFT_OBJREF is not set
                                        < # CONFIG_NFT_QUOTA is not set
                                        < # CONFIG_NFT_REJECT is not set
                                        < CONFIG_NFT_COMPAT=y
                                        < # CONFIG_NFT_HASH is not set
                                        < # CONFIG_NFT_XFRM is not set
                                        < # CONFIG_NFT_SOCKET is not set
                                        < # CONFIG_NFT_OSF is not set
                                        < # CONFIG_NFT_TPROXY is not set
                                        < # CONFIG_NFT_SYNPROXY is not set
                                        < # CONFIG_NF_FLOW_TABLE is not set
                                        > # CONFIG_NF_TABLES is not set
                                        1261,1264d1236
                                        < CONFIG_NF_TABLES_IPV4=y
                                        < # CONFIG_NFT_DUP_IPV4 is not set
                                        < # CONFIG_NFT_FIB_IPV4 is not set
                                        < # CONFIG_NF_TABLES_ARP is not set
                                        1294d1265
                                        < # CONFIG_NF_TABLES_IPV6 is not set
                                        1302d1272
                                        < # CONFIG_NF_TABLES_BRIDGE is not set
                                        docker 运行正常
                                        > docker ps
                                        CONTAINER ID   IMAGE                      COMMAND                  CREATED      STATUS         PORTS                     NAMES
                                        ff206fdf473a   rancher/k3s:v1.30.3-k3s1   "/bin/k3d-entrypoint…"   2 days ago   Up 8 minutes                             k3d-freshncp-server-0
                                        78f859e5c98b   registry:2                 "/entrypoint.sh /etc…"   2 days ago   Up 8 minutes   0.0.0.0:39301->5000/tcp   k3d-registry
                                        > uname -a
                                        Linux freshncp 6.1.75 #6 SMP Sun Aug 18 20:01:41 CST 2024 aarch64 aarch64 aarch64 GNU/Linux
                                          berkaroad @plumlis
                                            Resolve audio issues with the 6.1 kernel
                                            sudo tar -zxvf rk3588-es8316.tar.gz -C /usr/share/alsa/ucm2/Rockchip/
