    Which ppa for graphics acceleration on coolpi laptop (rk3588)?
    7 Posts 2 Posters 3.1k Views
    • enok71E
      enok71
      I'm trying to explore hardware acceleration features on my rk3588 based laptop. I run Ubuntu 22.04 as installed when I received it.
      Are there any package sources (ppas?) that I could add to make this work easily? Or do I have to recompile all the libraries myself from github repositories?
      I found ffmpeg-rockchip and compiled rkrga, rkmpp and ffmpeg-rockchip yesterday trying to get an ffmpeg that uses r3588 hardware video encoder. But it fails to run. Do I need to recompile libdrm also? The kernel?
      Thank you and best regards!
      /usr/local/bin/ffmpeg -f video4linux2 -i /dev/video0 -f hevc ../tst.h264
      ffmpeg version 50cc62684a Copyright (c) 2000-2023 the FFmpeg developers
        built with gcc 11 (Ubuntu 11.4.0-1ubuntu1~22.04)
        configuration: --prefix=/usr/local --enable-gpl --enable-version3 --enable-libdrm --enable-rkmpp --enable-rkrga
        libavutil      58. 29.100 / 58. 29.100
        libavcodec     60. 31.102 / 60. 31.102
        libavformat    60. 16.100 / 60. 16.100
        libavdevice    60.  3.100 / 60.  3.100
        libavfilter     9. 12.100 /  9. 12.100
        libswscale      7.  5.100 /  7.  5.100
        libswresample   4. 12.100 /  4. 12.100
        libpostproc    57.  3.100 / 57.  3.100
      Input #0, video4linux2,v4l2, from '/dev/video0':
        Duration: N/A, start: 14443.933156, bitrate: 147456 kb/s
        Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1280x720, 147456 kb/s, 10 fps, 10 tbr, 1000k tbn
      Stream mapping:
        Stream #0:0 -> #0:0 (rawvideo (native) -> hevc (hevc_v4l2m2m))
      Press [q] to stop, [?] for help
      [hevc_v4l2m2m @ 0x5566a0db90] Could not find a valid device
      [hevc_v4l2m2m @ 0x5566a0db90] can't configure encoder
      [vost#0:0/hevc_v4l2m2m @ 0x5566a0d810] Error while opening encoder - maybe incorrect parameters such as bit_rate, rate, width or height.
      Error while filtering: Operation not permitted
      [out#0/hevc @ 0x5566a0c690] Nothing was written into output file, because at least one of its streams received no packets.
      frame=    0 fps=0.0 q=0.0 Lsize=       0kB time=N/A bitrate=N/A speed=N/A
      Conversion failed!
      enok71E G 2 Replies Last reply Reply Quote 0
      • enok71E
        enok71 @enok71
        Ok the following command line actually seems to work with my own compiled ffmpeg-rockchip, based on my own compiled rkrga and rkmmp. And top shows zero cpu-load so the CPU is actually not used at all.
        ffmpeg -i /dev/video0 -c h264_rkmpp /tmp/tmp.mp4
        Still interersted in URL to some source of precompiled Ubuntu packages though. Thanks.
        • enok71E
          enok71 @enok71
          Answering myself once more ... there is a ppa here although I'm not sure that's the optimal one for rk3588?
          If someone is more sure of the best place to look for hardware accelerated software packages please help.
          • enok71E
            enok71 @enok71
            @enok71 Just in case someone reads my postings in this thread: The best source for coolpi hardware support packages is probably Georges ppa. Probably best to avoid mixed in packages from Liu Jianfengs ppa.
              george @enok71
              @enok71
              Due to copyright issues with ffmpeg, only limited decoding support has been provided for ffmpeg Rockchip.
                george @enok71
                @enok71
                The hardware acceleration software package currently defaults to using George PPA. We are currently researching a new branch and will release the results as soon as possible.
                  george @enok71
                  @enok71
                  George ppa provides ffmpeg source code and its patches, and can continue to develop on this code. We hope to support more formats. Especially in the coding part.
