    Installing Cockpit on coolpi
    1 Posts 1 Posters 509 Views
      • By default, the Cockpit package is included in the Ubuntu 22.04 default repository. You can install it by running the following command:
          sudo apt-get install cockpit -y
      • After installing Cockpit, run the following command to install the Podman module:
          sudo apt-get install cockpit-podman -y
      • After installing Cockpit, start the Cockpit service and have it start when the system reboots:
          systemctl start cockpit
          systemctl enable cockpit
      • You can also use the following command to check the status of Cockpit:
           systemctl status cockpit
      • You should see the following output:
      ●cockpit.service - Cockpit Web Service
           Loaded: loaded (/lib/systemd/system/cockpit.service; static)
           Active: active (running) since Tue 2023-11-21 08:44:56 UTC; 7min ago
      TriggeredBy: ● cockpit.socket
             Docs: man:cockpit-ws(8)
          Process: 336904 ExecStartPre=/usr/lib/cockpit/cockpit-certificate-ensure --for-cockpit-tls (code=exited, status=0/SUCCESS)
         Main PID: 336905 (cockpit-tls)
            Tasks: 3 (limit: 37954)
           Memory: 1.5M
              CPU: 358ms
           CGroup: /system.slice/cockpit.service
                   └─336905 /usr/lib/cockpit/cockpit-tls
      • At this point, Cockpit has started and is listening on port 9090. You can use the following command to view:
           ss -antpl | grep 9090
           LISTEN 0      0                  *:9090            *:*
      • Configure a UFW firewall and open port 9090
      • Now, open a web browser and use the URL https://your-server-ip:9090 Access the Cockpit web interface. You should see the Cockpit login page:
