    Node-RED Installation
    Scheduled Pinned Locked Moved Pi Gateway CP1B/CP2B/CP3B/CP3B-P
    1 Posts 1 Posters 411 Views
      Installation Based on Physical Machine
      curl -fsSL https://deb.nodesource.com/setup_20.x | sudo -E bash - &&\
      sudo apt-get install -y nodejs
      sudo apt install  npm
      sudo npm install -g --unsafe-perm node-red
      Based on Docker
      mkdir /home/iotts/node_red
      cd /home/iotts/
      sudo chmod 777 node_red
      sudo docker run -d --restart always -p 1880:1880/tcp -v /home/iotts/node_red:/data --name nodered nodered/node-red
      Start on Boot
      • Create a service
      sudo nano /etc/systemd/system/node-red.service
      • Paste the following content in the editor:
      [Unit]
      Description=Node-RED
      After=network.target
      [Service]
      ExecStart=/usr/bin/node /usr/bin/node-red
      User=sa
      [Install]
      WantedBy=multi-user.target
      • Reload the systemd manager configuration to make the new service effective:
      sudo systemctl daemon-reload
      • Start the Node RED service and set it to boot up automatically:
      sudo systemctl start node-red
      sudo systemctl enable node-red
      • Check the status of Node RED service:
      sudo systemctl status node-red
      Set user password
      • Open the settings. js file
      vim /home/admin/.node-red/settings.js
      • To modify the content of CredentialSecret, you need to set a key, not a login password. Save and exit.
      • Restart Ubuntu
      sudo reboot
      • Generate username and password, using admin as an example here
      node-red admin hash-pw
      admin@cp2b:~$ node-red admin hash-pw
      Password: $2y$08$cUm1LgtBnDt.b.az4IiLeuPCNb0LFv.hbnd71OWwd94j.GMF/WVnW
      • Open the settings. js file, modify the content of adminAuth, and copy the string from earlier. Save and exit.
      • Restart Ubuntu
